Metal on metal scrapping sound?
Zoofly
Post by Zoofly »
I'm getting a scrapping sound that sounds like metal on metal. I used to get this faint sound on start up but would go away when depressing the clutch. Now the sound is constant, but seems to be coming from the timing belt area. When I rev the engine, the scrapping sound matches the rpm. I have two short videos, one from the engine bay and one from the inside of the car. I'm curious as to what you think it is. I'm not too far from Allison's Automotive so worst case scenario would be to drive it out to him to trace it down.
Could be the clutch disc against the flywheel, or possibly the inner metal cover of the timing belt cover (although I don't really know what that means). Been reading old posts but not finding anything definitive.
https://youtu.be/60CWJpjpUaM
https://youtu.be/gX6Avwp8WJU
2020 124 Spider Abarth
2019 Alpha Romeo Stelvio - sold
1977 Triumph Spitfire
2017 Fiat 124 Spider Classica - sold
1999 Jaguar XK8 - sold
1998 BMW Z3 - sold
1988 Pontiac Fiero - sold
davidbruce
Re: Metal on metal scrapping sound?
Post by davidbruce »
In that area I would suspect something rubbing on the tin shields behind the belt cover. Could also be a failing water pump, tensioner or alternator bearing. Any play in the water pump or alternator pulleys?
Dave Kelly
Campbell River B.C.
1973 Sport(sold)
Spider951
Post by Spider951 »
Get a mechanic's stethoscope (they are cheap - I think I got mine at Harbor Freight, or you can make one with some tubing and a metal rod). They are good for trying to track down things that go bump (or scrape) in the night (or day). Be very careful, however, where you put the thing when engine is running!!!!.
Nut124
Post by Nut124 »
I vote for alternator brg. Remove the belt and check alt brg by hand like Dave says. You can start and run the engine for a few sec w/o the alternator and water pump to see if the noise goes away.
