Brakes woes
Posted: Thu Apr 28, 2022 9:32 pm
Just finished a complete redo of the suspension and brakes system—only thing not replaced on the brakes was the booster, steel lines and the compensator valve. Everything else is brand new: master cylinder, calipers, rotors, brakes hoses, compensator linkage and hand brake cable. Although I spent quite an amount of time vacuum and gravity bleeding the system—I expected that since it was completely empty it was going to take a long time to get the air all out. But apparently, I did not spend enough on it cuz my brakes are still feeling a bit spongy I think. Since I bought the car about a year ago, I don’t have a good reference point. I feel the brakes feel the same as before…a bit spongy. Is this the “real” feeling? Or should I feel them short and hard when I press the pedal?
