Fouled Spark Plugs? 1979
- Patron 2021
- Your car is a: 1979 Fiat spider 124
So while looking around at the engine and planning a carb plus intake mani upgrade I noticed my water pump leaking….Now I was planning a timing belt replacement this spring and already ordered the parts which included a new water pump so I have everything I need to replace it so that’s a bonus. While planning to do the timing belt and pump i pulled out two plugs just to have a look as I’ve read that I’ll need to check the engine for top dead center while working on the timing belt install. The plugs that came out do not look great to me….keep in mind I’m a newbie this is the first car I have really done any work on so lots to learn for sure but I’m really enjoying it and working along side my son has been great. Did some research based on how the plugs look and I feel like these would be classed as “fouled” …car running too rich? Honestly the car runs great and idles nice, there is some oil leaking from the valve covers on to the plugs…could this be the cause of the dirty plugs?
Re: Fouled Spark Plugs? 1979
They don't look shiny, so it's probably not oil fouling. It looks like it's running rich as you noted, and here are some possible causes:Pescado wrote:The plugs that came out do not look great to me….]
1. Wrong spark plugs. Champion RN9Y or the equivalent is what's specified.
2. Choke is not disengaging completely.
3. Car driven only on very short trips.
4. Thermostat not working so the engine is very slow to fully warm up.
5. Various carburetor issues including leaks in the hoses.
Do any of those seem like they might apply? By the way, go ahead and pull all 4 plugs and see if they all look fouled. If only two are fouled, it could be another issue.
Running too rich. Then again, rich usually runs OK, like you are saying, at the expense of fuel economy and some power.
Regarding your timing belt job. Carefully mark the crank and cam pulleys before taking the belt off so you can get it back in the same position. No need to find TDC as long as you can get it back the same it is now, since it runs good.
TDC mark is needed for ignition timing though.
- Patron 2021
Thanks Nut124 good to know.
Honestly I think I may hold off the timing belt for a while...seeing as I'm changing plugs, waterpump, drive belt, and have been in up to my elbows bumping things around I'd like to see how the car starts after its hibernation before doing too many changes...just in case things aren't good there will be less to trouble shoot if I'm not questioning my timing belt replacement. I know this means putting parts back on and than taking them off again to do the timing belt but I'll chalk it up as practice.
- Patron 2021
Here’s a picture of all 4 spark plugs…2 and 3 definitely look better. What’s the deal?
- Patron 2021
1. Very possible I will be replacing with the attached picture18Fiatsandcounting wrote:They don't look shiny, so it's probably not oil fouling. It looks like it's running rich as you noted, and here are some possible causes:Pescado wrote:The plugs that came out do not look great to me….]
2. How can I check this?
3. Some but not many…I try and make the trips no less than 20min as I have heard about this
4. How can I check this?
5. Most likely but this will be replaced soon
Thanks for the help
- Patron 2021
- kilrwail
Don't use those NGK racing plugs. They are too cold and the engine will barely run. As Bryan suggested, use Champion RN9Y or NGK BPR6ES.
Peter Brownhill
1977 Porsche 911S - track car
2022 Ram 4 x 4 - hauler
Peter Brownhill
As suggested by Kilrwail and Nut124, it looks like it might just be a matter of the wrong plugs. For posterity, here are the answers to your questions below.
1. Change out the plugs and see what that gets you.
2. Take off the air filter cover and you should see one, possibly two butterfly valves in the top throats of the carburetor. With the engine cold, they should be closed (or nearly so). When the engine starts, they should open slightly, and as the engine warms up, they should open fully.
3. Sounds like short trips are not the problem.
4. Observe your temperature gauge. Unless you are in a super cold climate, the engine should reach normal operating temperature (about halfway on the gauge) in 10 or 15 minutes (5 to 10 minutes in the Summer). If the gauge shows "cold" for much longer than this, your thermostat could be stuck open. Or you're just in a really cold climate.
5. See answer #1 above.
- Patron 2021
Ok thanks guys…the plugs in the picture are champion 3415.
According to google, that Champion plug correlates to NGK heat range of 5. The recommendation for normal use is NGK 6. The champion plug is hotter than NGK 6 so any fouling is unlikely to be because of the plug. 2 & 3 look pretty normal for a carb engine.Pescado wrote:Ok thanks guys…the plugs in the picture are champion 3415.
Single carb/manifolds do not always distribute even mixture to all cylinders.
The NGK race plugs are NGK heat range 9. Pretty much full race only.
I'm kinda getting the impression that the "Italian Tune-Up" is what you need. Drive the engine hard, 4000 to 6000 rpm at full throttle for a while, and I'll bet your spark plugs will look perfectly normal. These engines love that.
Just remembered that this is a 2L engine, so perhaps 4000 to 5000 rpm is a better idea.18Fiatsandcounting wrote:Drive the engine hard, 4000 to 6000 rpm at full throttle for a while, and I'll bet your spark plugs will look perfectly normal.
No point in stressing what might be a tired engine.
- Patron 2021
Ya I rushed into buying those plugs…thought I would be ok seeing as they came from a Fiat speciality shop, still my bad. The intake manifold on my 79 is still the original double…Guess I’ll be buying some new plugs thanks for the info.Nut124 wrote:According to google, that Champion plug correlates to NGK heat range of 5. The recommendation for normal use is NGK 6. The champion plug is hotter than NGK 6 so any fouling is unlikely to be because of the plug. 2 & 3 look pretty normal for a carb engine.Pescado wrote:Ok thanks guys…the plugs in the picture are champion 3415.
- Patron 2021
Well Bryan this sounds like it will be the most exciting of any repairs I’ve done yet…lol.18Fiatsandcounting wrote:Just remembered that this is a 2L engine, so perhaps 4000 to 5000 rpm is a better idea.18Fiatsandcounting wrote:Drive the engine hard, 4000 to 6000 rpm at full throttle for a while, and I'll bet your spark plugs will look perfectly normal.
Can you expand on “tired engine” for me
