Hello, I made this custom aluminum cold air box from 3/16" thick aluminum sheet that I had laying around. First I made a mock up out of cardboard, taped it together then once I was satisfied I flattened it out and cut the pieces from aluminum. You can see the various folds and hammer marks, and few solder blobs. I used aluminum angle bar for base from home depot. Additionally a 1/4" thick plate for the box to AFM. Since I don't have a gas welder I used low temp aluminum solder sticks from harbor freight. Just tinkering and a we bit or creativity. Oh I used yellow bottle gas still have to clean up but it works great.
Enjoy!.
Victor
Custom Aluminum Cold Air Box
- Your car is a: 1984 Pinanfarina spyder
- Contact:
1971 MGB Roadster (sold)
1977 fiat 124 (sold)
2010 Prius
2001 Sequoia
2006 20' REgal bowrider boat.
1984 Pinanfarina
2010 Prius
2001 Sequoia
1984 Pinanfarina
- Contact:
Re: Custom Aluminum Cold Air Box
OK used imgur for pics.
2010 Prius
2001 Sequoia
1984 Pinanfarina
2010 Prius
2001 Sequoia
1984 Pinanfarina
Very cool. How well do those aluminum solder sticks work? I've never tried them but always wondered.
- Contact:
-Bryan, Not too difficult once you get the hang of it. Key is parts have to be really clean. One has to spread the heat around as the stick starts to melt. What I like is that once it melts and cools the joint can be filed and sanded to look great, I used a dremel. Down side is too much heat one can melt the items being soldered. Like anything else it take practice to get the hang of it.
2010 Prius
2001 Sequoia
1984 Pinanfarina
2010 Prius
2001 Sequoia
1984 Pinanfarina
Very cool indeed!
I have always wondered whether the low temp alu brazing sticks are for real.
Do you think the welds all are bubble tight, continuous?
I may have to try this one day.
- Contact:
So far the joints are OK. I did a water test. I also painted transparent fllex seal in the interior to be sure.
Next project will be a radiator over flow tank. Gonna embed a glass window or glass tube to see level.
84 Azzura.
Victor
84 Azzura.
Victor
2010 Prius
2001 Sequoia
1984 Pinanfarina
2010 Prius
2001 Sequoia
1984 Pinanfarina
