Fuel Pump and AFM jumper
Gotta love that wiring . . .
tima01864
Patron 2021
Patron 2021
Post by tima01864 »
One of the previous owners jumped the Fuel pump , Just cut the green black wire and hot directly to the fuse box. The past owner replaced the AFM and left it. I reconnected the cut green black wire, It now works off the AFM, Easy fix, Now safer and starts beautifully, It may even be more responsive or just the car wash effect.
spider2081
Patron 2024
Patron 2024
Re: Fuel Pump and AFM jumper
Post by spider2081 »
Sounds great. I don't understand why so many FI Spiders have the fuel pumps hot wired bypassing the air flow safety switch circuit. Maybe there was an intermittent problem and a PO thought bypassing the circuit was the easiest solution.
tima01864
Patron 2021
Patron 2021
Post by tima01864 »
spider2081 wrote:Sounds great. I don't understand why so many FI Spiders have the fuel pumps hot wired bypassing the air flow safety switch circuit. Maybe there was an intermittent problem and a PO thought bypassing the circuit was the easiest solution.
The guy I bought the car from replaced the AFM and left the PO's fix. Glad it was easy to revert to the AFM. I should not of waited so long to
fix it, The engine kicks over much better. Having the pump run off the key is annoying and could be dangerous.
tima01864
Patron 2021
Patron 2021
Post by tima01864 »
I had a little problem this afternoon, Since I removed the direct current to the fuel pump.
The engine sputtered like not getting enough fuel, I pulled over to a stop, Then the engine continued to behave normally.
The fuel pump on it's way out?
The dual relay (Which was not being used for the pump and AFM) is or was going out?
