I'm noticing what seems to be coolant seeping from the intake side of cylinder #1. It's green, so that should be coolant. By the looks of it it seems to be coming from where the intake manifold meets the head. It's not a serious leak yet, and I don't have coolant in the oil, or oil in the coolant. So thinking (hoping) there is a coolant journal behind the intake manifold and a new manifold gasket would solve the issue.
Dave
Coolant leak by intake manifold
Re: Coolant leak by intake manifold
Dave, yep, green would be coolant. There is a coolant passage through the intake manifold, so chances are it's just an intake manifold gasket that's gone bad, and nothing more serious. Once you get the manifold off and clean the mating surfaces on it and the head, use a straightedge or the like to make sure nothing's warped. Unlikely, but it can happen.
But before you pull off the manifold, check to make sure all 6 bolts/studs/nuts are torqued correctly as occasionally a leakage problem can be "solved" with a re-torqueing. 18 ft lbs is what I recall, and you don't want to go any tighter than the spec as the threads in the aluminum head can strip fairly easily. If it were me, I'd replace the gasket, but you might be able to get by with retorqueing any loose bolts/studs.
