gearbox measurement help
rug
Your car is a: 1971 sport coupe
Post by rug »
I need some help with a gearbox measurement. If someone has a gearbox laying around, could you measure this for me? I need the distance from the bellhousing from to the gearstick (see image). This is quite hard to do while the gearbox is in the car :)
Nut124
Re: gearbox measurement help
Post by Nut124 »
I have a gearbox sitting in the garage but do not understand what you need and cannot open picture.
Nut124
Post by Nut124 »
My spare is missing the shift tower.
I measure 18.5 +/-0.2" from the block to the center of the shaft just forward of the speedo gear.
Rigger178
Post by Rigger178 »
Hi, from the shifter in neutral position to the mating surface of the bell housing is 26 3/16” or 66.5 cm
rug
Post by rug »
Thanks guys!
That's exactly what I needed! Don't want to say too much what I need it for but if it all works out it will show up in the "custom stuff" section soon (well, in a few month..)
/Carl
SteinOnkel
Post by SteinOnkel »
Rigger178 wrote:Hi, from the shifter in neutral position to the mating surface of the bell housing is 26 3/16” or 66.5 cm
And it feels like 166.5 when you're installing the bleeding thing.
Pro tip: center console out, metal plate underneath out.
