New member
New member
Hey there folks! Just joined the forum here after purchasing my first fiat spider. It's a 1979, in pretty good condition, and I'm the second owner. I'm hoping to get it fixed up and running better than it has been in some time. I'm looking at an engine rebuild, some body work, all new paint, and likely a new interior. Hoping also to upgrade to fuel injection. In any case, I'm excited to get going on all this, though it is a blast to drive even now. Should be a grand time!
Re: New member
Are you planning on doing a Fiat injection, say from an 80-84 spider, or an after market injection.
1987 Lotus Super 7 clone
1981 Fiat Spider 2000 AT
1982 Fiat Spider 2000 5sd
1970 Fiat Coupe
1970 Fiat Coupe
Re: New member
I am looking at that option. Basically I want to make the car the best that it was intended to be, and I think the fuel injection is the way to go for that. I'm not sure when I'd be looking at that, because I'm thinking some new piston rings and bearings would do it some good, and I'm not sure when I'll be doing that. But around that time is when I'd be looking at the fuel injection system.
- Your car is a: 69 AS Spider
Re: New member
Hi
and welcome too! From where are you? And can we see some pictures of your car?
Good luck for your planned work!
Bye, Ralf
Bye, Ralf
69 AS Spider
the Worldwide Spider Register
