Who ever thought THIS was a good idea?
wetminkey
Post by wetminkey »
Drilling holes in the top of the shock tower!?
Looking up, through the top of the tower:
You can see the slit, cut in the upper spring mount, to drill from below, to above.
For cripes' sake, what happened here!?
1988 Mazda RX-7
1979 Fiat Spider 2000
1976 Camaro
1972 VW Superbeetle
1969 Ford F100
1968 Mustang coupe
DieselSpider
Re: Who ever thought THIS was a good idea?
Post by DieselSpider »
Perhaps someone drilled through a shock to drive a pin through to aid in its removal. I would have taken a die grinder to the shock stud and cut it down to the washer from above.
Is that a tack weld there too thats been drilled out?
wetminkey
Post by wetminkey »
Bizarre, huh?!
1988 Mazda RX-7
1976 Camaro
1972 VW Superbeetle
1969 Ford F100
1968 Mustang coupe
