FI Intake manifold removal.
- Your car is a: 1980 fiat Pininfarina spider 2000
I have a 1980 spider 2000 FI. I removed three bolts and two nuts that seems to be holding in the intake manifold. I also unbolted a small bracket that holds on to the top of the manifold as well as the camshaft housing. However, no matter how much I shake it will not come off. am I missing any connections or is it just hard to get off?
- Patron 2021
Re: FI Intake manifold removal.
Do you mean the Plenum? The cover that holds the throttle?
- Your car is a: 79 Spider
I think this question is in the wrong area.
RoadKill !
1979 Spider
1962 Corvair
2016 Z 71 Crew Cab
( someday a 59 Impala 2D
1979 Spider
1962 Corvair
2016 Z 71 Crew Cab
