REPLACING HEAD GASKET
- Your car is a: 1982 spider
The head gasket on my '82 took a dump. Can the head be removed with the intake still attached? What about the exhaust manifold? Any tricks or pitfalls to know about? Thanks
- Patron 2021
Re: REPLACING HEAD GASKET
I instlled mine with the intake and plenum attached, The only bad about removing the head was at the exhaust downpipe. I broke off three or four studs and had to have them replaced. The nuts on the manifold came off, Maybe a good time to have the cylinder head rebuilt?
- Your car is a: 79 Spider
Yes, in fact it may be easier then trying to get everything off first. It will take two people to lift it off safely but easily do-able. Start spraying penetrating oil on the exhaust manifold nuts now and give it a few days.
