Transmission mounting dimensions needed for unusual engine swap.
- Your car is a: 1982 Pininfarina Spider
I need to get the transmission dimension from engine mount hole to mount hole And dimension to the input shaft. A friend gave me a Honda J35A4 engine (3.5l -260hp). It looks like it will fit so I need to make a adapter plate, modified flywheel and flywheel spacer. Once I have good dimension, I can have t he adapter and spacer water jet cut and the flywheel machined. Anybody have some factory drawings?
Bill Woodbury
Design Engineer
Zero Shock Seating
1982 Spider 2000
Design Engineer
Zero Shock Seating
1982 Spider 2000
Re: Transmission mounting dimensions needed for unusual engine swap.
Sorry, I can't help with the factory drawings. Just a thought: while I'm intrigued by the thought of 260 HP in a spider, would the rest of the drivetrain be able to handle it? Transmission, clutch, u-joints, differential, engine mounts, crossmember, etc? Or were you going to upgrade those as well?
I have serious doubts the rest of the drive train will handle it but I wont know until i blow them up. Anticipating having to upgrade to miata parts.
Bill Woodbury
Design Engineer
Zero Shock Seating
1982 Spider 2000
Design Engineer
Zero Shock Seating
1982 Spider 2000
Ambitious project. I want to see this when done.
I do have an extra Fiat trans sitting in my garage, could try to measure.
@OP
I can send you an empty 124 spider transmission if you want. There are no shop drawings afaik, you'll have to measure and make your own.
