how to remove throttle cable from linkage
Zoofly
Post by Zoofly »
I can't remember how to remove the throttle cable from the linkage. I know it's simple because I've seen it done before. Can someone tell me the trick?
2020 124 Spider Abarth
2019 Alpha Romeo Stelvio - sold
1977 Triumph Spitfire
2017 Fiat 124 Spider Classica - sold
1999 Jaguar XK8 - sold
1998 BMW Z3 - sold
1988 Pontiac Fiero - sold
Re: how to remove throttle cable from linkage
There's no trick really. Put your left hand behind the clip, and using your right hand with a screwdriver, push the clip off of the ball on the spring lever assembly.
Or, just wrap the clip in wads of masking tape, and push it off. That way, you can easily find the clip when it shoots off into the dark recesses of your garage.
Both methods work.
