I have just started hearing a hissing sound from where the brake pedal rod enters the servo. This is accompanied by a hestitating of the engine.
Are we talking about the need of replacing the servo ?
regards
geoff
brake servo hissing
- Your car is a: 1982 Spider
Re: brake servo hissing
Diagnosis by part replacement is particularly inconvenient on the brake booster. Two other air leak suspects are the check valve on the front of the booster where the vacuum hose connects and the vacuum hose itself. Put a helper in the driver's seat while you get your ear closer to the booster while the brake pedal is depressed. But yes, the rubber diaphragms inside the booster housing have a finite life.
- courtenay
Yes. Use vise grips to Pinch the vacuum hose leading to the booster. Then put your foot on the brake. If no whoosh and no change in idle, the unit is pooched. See my booster replacement thread in the General Maintenance section.geoff wrote:I have just started hearing a hissing sound from where the brake pedal rod enters the servo. This is accompanied by a hestitating of the engine.
regards
geoff
http://www.fiatspider.com/f15/viewtopic.php?f=9&t=39014
Bruce Shearer
'80 Spider Fi
'10 Volvo XC70
'06 GMC 1 Ton PU
'80 Spider Fi
'10 Volvo XC70
'06 GMC 1 Ton PU
Text book example of vacuum leak at brake booster.
Enjoy. It's a pita to replace, just like everything else on these cars.
