WHAT IS THIS!? Steering column 'bolts'
wetminkey
Post by wetminkey »
,...these damned REAR steering column fasteners!? No idea how to remove them (to replace with proper fasteners),...
Bolts in the front, weird stuff in the rear. Factory,...as far as I know.
Bent them while removing/installing the instrument panel, so the tabs that are bent down used to be horizontal.
1.) How do I get them out?
2.) What to replace them with, once I do?
Any ideas? I have never seen this type of fastener before.
Thanks, Todd.
1988 Mazda RX-7
1979 Fiat Spider 2000
1976 Camaro
1972 VW Superbeetle
1969 Ford F100
1968 Mustang coupe
NGK
Patron 2019
Patron 2019
Your car is a: 1980 124 fiat spider 2000
Re: WHAT IS THIS!?
Post by NGK »
I just took out the bolts and that gave it enough play they just popped off don't know if that helps.
dinghyguy
Your car is a: 1981 spider
Re: WHAT IS THIS!?
Post by dinghyguy »
there was a post a while ago about them, perhaps steering column or ? was the topic....i seem to recall they were bolts and the owner removed them and replaced them with standard bolts, but not sure.
dinghyguy
1981 Red Spider "Redbob"
1972 blue Volvo 1800ES "Bob"
1998 Red Ford Ranger
wetminkey
Re: WHAT IS THIS!?
Post by wetminkey »
First,...when I found that there is no way to remove them (head is a round button, and the 'non-fastener' fits tightly into the rectangular recess, just above it), I removed the front two bolts to gain clearance for dash removal, but then (at some point, with dash out) I leaned on the column slightly, and the light force bent the side tabs downward.
There is no way to grip the head, and they will not turn in the recess. I think I see threads on the far side, but it sounds like I'm going to have to injure myself again, crawling under the steering column, to be able to figure these out further.
I'll whip out a pair of my Vice-Grips,...
Thanks, guys,...more if I figure them out.
1988 Mazda RX-7
1976 Camaro
1972 VW Superbeetle
1969 Ford F100
1968 Mustang coupe
wetminkey
Re: WHAT IS THIS!?
Post by wetminkey »
Info from other Fiat folks:
"The square washer with wings is a "Steering Column Indexing Plate Washer" - Bayless has them for $2.79. I think the wings are the breakaway part that allows the column to pivot upward about the front connectors in a collision."
"the original bolts were a break away head, once the proper torque was reached the bolt shaped head broke off. Same as the ignition switch bolts on the x1/9 and 131 type switches."
So,...I'll get 'em out, save the rectangular washer to help align the steering column, and replace with hex-headed bolts.
Hope that helps someone else,...
Thanks for the help, all. The mystery is no more! Todd.
1988 Mazda RX-7
1976 Camaro
1972 VW Superbeetle
1969 Ford F100
1968 Mustang coupe
wetminkey
Re: WHAT IS THIS!?
Post by wetminkey »
Piece of cake!
Vice-Grips with a finer tip will back out the fine-threaded, round-headed 'bolt' (M6, via another Spider owner, and that's what I measure) - a little more difficult on the passenger's side, due to the ignition switch,...but they're not horribly tight, and there's JUST enough room to work. Didn't even hurt myself!
There's a lockwasher on each. And the rectangular washer has a larger, lighter-metal rectangular plate spot welded to it (that's the part that I bent). I simply pounded the side tabs of the rectangular washer (the ends of the plate) flat, and I'll reinstall it, and the lockwasher, with new, hex-headed M6 bolts.
Hope that helps someone, someday,...
1988 Mazda RX-7
1976 Camaro
1972 VW Superbeetle
1969 Ford F100
1968 Mustang coupe
unkelkennie
Your car is a: 1969 spider
Re: WHAT IS THIS!? Steering column 'bolts'
Post by unkelkennie »
I used a small cut off wheel to make a slot and used a slotted screw driver on a 69 124
