Trasmission oil
Trasmission oil
I just aquired a used 5 speed for my long broken '77 Spider. Can someone refresh may memory as to what oil I should use in this transmission. I know it's not 90wt. Thanks...J.D.
Re: Trasmission oil
It is 90W non-EP oil, and you put in 1 3/4 quarts.
Make sure it is a GL-1 NOT a GL-5 oil
Re: Trasmission oil
All my old brain remembered was that it was different than what we used in our other cars. That's why I asked...the brain is getting old ...J.D.
- ga.spyder
Re: Trasmission oil
If you cant find ot locally ,Vick Autosports has it.There have been a lot of posts on substitute fluid,but the safe ,proven ,factory rec'd route seems the one to follow.
Craig
Craig
Craig Nelson
Fling It Around Turns !
Re: Trasmission oil
I concur with Craig. I thought I'd try a synthetic oil with a GL1 rating (Amsoil) and shortly thereafter the tranny bit the dust. It could have been coincedence, but from then on, I'm sticking with pure GL1 gear lube.
Ron
Ron
Re: Trasmission oil
If you can't find the right fluid in So Cal, you're looking in the wrong spots
