ecu + air flow meter
nalle
Your car is a: Spider 2000 1982
Post by nalle »
I had some problems with the flap inside afm. They are now solved,
During the problem, i was wondering is it possible to change ecu and afm from spider equipment to Fiat Argenta /Regata /132 ecu and afm.
I checked that other injection component are the same (ok, filter is different). The non spider components are much more easier to find, at least in Europe. my car do not have any more cat so I do not need lambda sensor either. (argenta / regata do not have lambda)
Correction: the fuel pressure regluator is also different 2,5 bar => 3,0 bar and chnge throtle position switch has to be changed to a potentiometer.
Has any one done this?
Spider 2000 cs0 1982
Spider 2000, 1982
Ex Jaguar X-type 2.2, 2009
Jaguar XE 2.0 AWD
"A single fact can spoil a good argument"
76was124
Patron 2019
Patron 2019
Re: ecu + air flow meter
Post by 76was124 »
Sorry, I do not know, but the site in the link below might help determine, some posts seem to indicate compatibility with certain model numbers.
https://t124.com/forum/forum/general/te ... flow-meter
Current 81 Spider 2000
Previous 76 Spider
