Starting problem
- Your car is a: 1974 Fiat Spider 124 sport 1800
Starting problem
I get a clacking sound when my 1974 spider 124 sport 1800 won't start. What could be causing the car to start intermittently? Most days she starts but sometimes clack, clack, clack.
Re: Starting problem
Weak Battery
Faulty ignition switch
Faulty wiring
Faulty grounds
Faulty starter
Faulty wiring
Faulty grounds
Faulty starter
Start with simple and easy and work upstream. Voltage check between battery terminals then clean and tighten battery clamps. Replace the starter when you've eliminated everything else.
I have a new battery, new starter.rridge wrote:Start with simple and easy and work upstream. Voltage check between battery terminals then clean and tighten battery clamps. Replace the starter when you've eliminated everything else.
Steiny's (SteinOnkel's) list above is a good one, and it sounds like you've eliminated some of these possibilities. Check first that you have good ground cable connections between the body and the clutch bellhousing. And check the ground cable from the battery post to the body of the car. Your '74 still has the battery in the engine compartment, right? (later models had it in the trunk)
My guess is a faulty ignition switch (quite common) or the wires that attach to it in the back. Try wiggling those wires when you experience that "clack-clack" sound. If the car then starts, it's most likely a wiring connection or switch issue.
Those connections on the back of the ignition switch have caused this same problem in my car.
Thank you Bryan, I have not looked into the ignition switch. Thats my next project! Thanx again Brian!18Fiatsandcounting wrote:Steiny's (SteinOnkel's) list above is a good one, and it sounds like you've eliminated some of these possibilities. Check first that you have good ground cable connections between the body and the clutch bellhousing. And check the ground cable from the battery post to the body of the car. Your '74 still has the battery in the engine compartment, right? (later models had it in the trunk)
They're a little long in the tooth these days. OEM replacements are outrageously expensive.
If you get a new Lada switch which is an order of magnitude cheaper, make sure you wire in relays.
