Heater pipe
rodo
Your car is a: 1981 Spider
Heater pipe
Post by rodo »
Had to replace the pipe from the heater core. On the hose side the new one does not have a rolled lip so as to hold the hose more effectively. Seems even when I tighten it pretty well it is still not as good a connection as one would wish. What do the rest of you do with these second rate pipes?
Re: Heater pipe
If the rubber hose is in good shape and the correct size for the heater core pipe, you should be fine. Use a good hose clamp and make sure it's tight of course.
On a few Fiats that I've had, the end of the pipe was essentially rusted away, and so I used a hack saw to take off about a half inch of rotten pipe (which of course removed the lip) and then readjusted the hose length to match. I don't recall ever having a problem.
rodo
Re: Heater pipe
Post by rodo »
Thanks a ton, Bryan.
DieselSpider
Re: Heater pipe
Post by DieselSpider »
You can also do as they do in the boatyard and double clamp the hose being sure to orient the second clamp 180 degrees from the first whenever possible.
