Will try and use an offset wrench I think. Just a little tight in that area for use of that wrench. First time changing one, any tips?
That shielding is to protect the signal from noise from your ignition system.RRoller123 wrote:So there seems to be a woven shield around the sensor wire, that gets grounded back through the harness, and the unit itself is electrically isolated from the exhaust?
