Page 1 of 1
Rear center bump stop
Posted: Wed Dec 25, 2019 11:24 pm
by DustyDave
Hello all, Merry Christmas! I just got a new rear suspension center rubber bump stop to replace the old one that was dry rotted. Old one simply came apart when pulling it out. The question is how to install the new one. Trying to simply push it is not working, even with stop wetted with cleaner. Side braces on the mount prevent twisting it in. Lack of access to back end makes it hard to grab and pull through. If anyone has done this before and has a good method or tips to suggest, I like to hear your input. Thanks!
Re: Rear center bump stop
Posted: Thu Dec 26, 2019 11:52 am
by 18Fiatsandcounting
Having never replaced these bump stops on my cars, I can only offer the general advice of warming the bump stop and using dish detergent as lubrication (some people swear by Dawn, but I doubt the actual brand makes much difference). I imagine that there once existed some sort of assembly tool that would tightly compress the barbed end, allowing it to slip through its mounting hole before releasing the tool.
Sorry I can't be of more help...
Posted: Thu Dec 26, 2019 11:54 pm
by DRUMMOND
Posted: Fri Dec 27, 2019 12:58 pm
Awesome solution, DRUMMOND, I like that!!
Posted: Fri Dec 27, 2019 7:20 pm
by DustyDave
Yes, thanks for sharing that method... I will give it a try and let you know what I think!
Posted: Sun Dec 29, 2019 12:27 pm
by DieselSpider
Same principle as installing an old school window gasket.
Posted: Wed Jan 15, 2020 9:15 pm
by DRUMMOND
Hi DS
I actually got the idea from repairing my motorcycle tyres with the mushroom style rubber plugs!
