reverse gettubg harder to engage
donm
Your car is a: 1980 spider [carb]
Post by donm »
Lately my '79 is getting harder to shift into reverse. I've been having to play with the shifter to get it to engage. What could cause that? Otherwise, the tranny shifts fine.
1979 Spider
2001Saab SW
2004 Saab Aero
tima01864
Patron 2021
Patron 2021
Re: reverse gettubg harder to engage
Post by tima01864 »
Good question, I run it through the gears at stop before engaging reverse, otherwise it will grind. My shift lever unbolted earlier this year. I fixed that with a locking nut, First indication of that was hard shifting into first. But fixing that did not fixthe reverse problem.
Are you pulling up or pushing down on the gearshift lever when you try to engage reverse? Depending on the model year, you either push down or pull up, and there is a little stud in the rear extension of the transmission that prevents you from selecting reverse by just pulling backwards. Kind of a safety feature to prevent you from accidentally trying to engage reverse when you're moving forward.
Perhaps that stud is out of adjustment? Another possibility is just that your transmission is just worn, making it harder to engage reverse.
RRoller123
Post by RRoller123 »
Go into SECOND, and slightly engage the clutch. then go into Reverse. It generally works to smooth things out.
