Page 1 of 1
124 Spider Alignment Specs
Posted: Thu Jul 04, 2019 6:22 pm
by THEFIAT
My 1980 Fiat Spider 2000 is set up with the Whoa Brake package, the upsized 22mm Front Sway bar (same as the last Pininfarina Azzura, I believe), and 205-50 /15 tires.
I have been burning the inner edges of the tires, and need to correct the front alignment. :(
I am in the process of removed the battering ram bumpers, in favor of the aftermarket version of the original OEM spider chrome (no over-riders) mounted on the 1980's bumper shocks.
Need advice on proper alignment specs for this setup.
I do not have the 1985 alignment spec (haven't found it!)
Any assist and learned advice greatly appreciated.
Jon Boyd
[THE FIAT]
Re: 124 Spider Alignment Specs
Posted: Thu Jul 04, 2019 8:51 pm
by tima01864
Log in create an account with Mirafiori look in the library you will have good luck finding the specs
Posted: Fri Jul 05, 2019 9:34 am
by THEFIAT
I've tried that, but do not find anything there related to the later model Pininfarina Azzura Spider, which had the stiffer front stabilizer bar.
