The problem is that the car picks up, but practically does not accelerate and does some black smoke.
It implies that there is a lot of gas and little air.
Might be the angle of the pic, or I might be wrong,...what's the possibility that one of these cams is a tooth off,...? Timing holes appear slightly asymmetrical,...
1988 Mazda RX-7
1979 Fiat Spider 2000
1976 Camaro
1972 VW Superbeetle
1969 Ford F100
1968 Mustang coupe
I already solved the problem !!!
Tab of the fifth injector exchanged with that of the air controller of the admission.
Thank you so much guys for the help
That distributor rotor is incorrect for the electronic distributor. That rotor does not contain a resistor between the carbon button and the tip like it should. That rotor is for the early block mounted distributor. IIRC there may also be an interference between the rotor and the centrifugal weights not allowing them to move and advance the timing when the RPM's increase.
