1982 Spider 2000 sat in garage 20+ Years
wabailey
Your car is a: 1982 Fiat Syoer 2000
Post by wabailey »
I have a 1982 Fiat Spider that has been sitting for 20+ years. As far as I know nothing special was done to preserve at the time it was parked. Looking for any information, advice, and opinions on whether its worth getting it going again. I have time and money but not a lot of experience on major rebuilds. Thanks for any ideas the forum may have.
tima01864
Patron 2021
Patron 2021
Re: 1982 Spider 2000 sat in garage 20+ Years
Post by tima01864 »
Welcome, You will find good info here. One question where or what state do you live?
wabailey
Post by wabailey »
I’m in southwest Ohio
spidernut
Post by spidernut »
It really depends.
At a minimum:
- Drain, flush and clean fuel tank
- Replace all rubber fuel lines
- Replace fuel filter
- Replace fuel injector fuel lines
- Replace timing belt and tensioner bearing
- Replace brake hoses
- Flush brake system
- Replace radiator hoses
- Replace belts
- Flush coolant system
- Change oil
- Inspect brake calipers and pads (replace as necessary)
- Inspect ball joints, suspension bushings, tie rods
That would be enough in most cases to start and drive the car to see what other issues it may have. If the car is generally free of rust and in reasonable condition, it is worth repairing and getting back on the road.
John G.
1977 Spider (Sold 2017)
1979 Spider (Sold 2015)
1980 Spider (Sold in 2013)
1981 Spider (Sold in 1985)
DieselSpider
Post by DieselSpider »
Add grease everything and be sure to top off the idler arm bushings. If there are no grease fitting on the ball joints or tie rod ends get a grease needle so you can get some grease back in them. After all this time the oil and pressure additive/carrier in the grease have separated. Be sure to clean and repack the front wheel bearings too so you do not score the spindles on the first test drive making it so you'll need new spindles. Be sure to put a good quality silicone brake grease on the calipers sliding parts, wedges and such too.
