Late Model Spider Frame on an Early Model Car
ITA124
Post by ITA124 »
Hi All,
As the subject line indicates. I have a 1976 model Spider and want to install a late model convertible roof frame from a circa 1980 model. Do these bolt in? I hear that the header bow is the only difference. Is this correct?
Cheers,
Paul
daved
Your car is a: 1969 fiat 124 spider
Re: Late Model Spider Frame on an Early Model Car
Post by daved »
Think the latches are different also.
samakijoe
Your car is a: 1975 Fiat 124
Post by samakijoe »
Reading the header, I thought he was trying to transplant a new under carriage/running gear to an old body.
I thinking, that would be a real bag of worms.. :roll:
SAMAKIJOE
AKA GRANDPA GRUMPYPANTS
DieselSpider
Post by DieselSpider »
Not sure however I see three different convertible top frames listed for the 124 Spiders and they are sold without the front bow. Its not apparent if the difference is just the tint of the rear side windows or not.
See: https://www.midwest-bayless.com/c-19-to ... 4SC-0.aspx
MattVAS
Your car is a: 1976 Fiat Spider 124
Post by MattVAS »
It is just the header bow that is different. And yes the latches may be different depending on exactly which year you get the top frame from.
That said the latches don't really matter as they are still lined up in the same spots so just use the ones that fit the header bow.
Matt Phillips
Vick Auto - Manager
http://www.vickauto.com
