ADHA to ADFA retrofit
When retrofitting an adfa carb from an adha, what do you do with the open vacuum fitting on the high idle capsule? I know it's not functional on the adha but is it on the adfa? Or just plug it?
Re: ADHA to ADFA retrofit
I do not know the answer to this question, but my 28/32 ADHA has a blue plastic identifier on that vacuum fitting, indicating that it would attach to a blue vacuum line,...a tiny clue, but perhaps it will make more sense to you since you've been researching this,...
Best of luck!
Todd.
Best of luck!
Todd.
1988 Mazda RX-7
1976 Camaro
1972 VW Superbeetle
1969 Ford F100
1968 Mustang coupe
1976 Camaro
1972 VW Superbeetle
1969 Ford F100
1968 Mustang coupe
