I recently bought a 71 sports coupe in really great shape. There are som minor issues, but for a car this old I am really happy. I will be posting in the Intro section as soon as I get som pictures....
I also came across some throttle bodies from jenvey so I am planing om replacing the stock weber IDFs.
Since I need an EFI system in the car I am also concidering using the same system to control the ignition. Has anyone else converted to Megasquirt or any other EFI system? Where did you get the trigger signal from? Sensor on the distributor or install a trigger wheel?
/Carl
ignition trigger pickup (FI conversion)
- Your car is a: 1971 sport coupe
