Close enough?
PaulC
Patron 2022
Patron 2022
Close enough?
Post by PaulC »
After lining up the zero tdc to check the cam alignments, found them to be ok. Photos show each as well as the timing mark which is slightly off from tdc so I'm calling the cams good.
[img]https://i.imgur.com/qsjbTk8.jpg[img]
Cams look good
[img]https://i.imgur.com/dM2byTM.jpg[img]
[img]https://i.imgur.com/WihqNYp.jpg[img]
Is the dizzy close enough to #4 (black marks) or does it need to be repositioned?
[img]https://i.imgur.com/1QwiU3L.jpg[img]
PaulC
Patron 2022
Patron 2022
Re: Close enough?
Post by PaulC »
Nuts! Photos didn't post! How come??
RRoller123
Re: Close enough?
Post by RRoller123 »
Odd, it looks right. Maybe copied the wrong option from the imgur list? try another one.
PaulC
Patron 2022
Patron 2022
Re: Close enough?
Post by PaulC »
My bad. Missed the forward slash in the last img
So here's the timing mark:
And the cams:
And finally the dizzy:
The cams look right on given that The timing mark is a tiny bit off.
The dizzy is close (see the two black marks) but close enough to #4?
rebar1111
Patron 2019
Patron 2019
Your car is a: 1979 124Spider
Re: Close enough?
Post by rebar1111 »
Yes. Your query caused me to look at mine. Mine was nor there and it has cause mine not to start. All is fine now.
Thanks.
PaulC
Patron 2022
Patron 2022
Re: Close enough?
Post by PaulC »
While rebuilding the dizzy, I noticed two punch marks on the edge of the housing. You can see them in the photo showing where the #4 position of the rotor is (the black mark). Curiously they appear to indicate the same thing - the #4 position of the rotor. Not sure if this was a factory mark or one PO's may have added.
Has anyone else seen these?
rebar1111
Patron 2019
Patron 2019
Re: Close enough?
Post by rebar1111 »
My 79 2L has a line, cast in place, on the distributor base at the 0-10 deg setting.
