Can the windshield assembly, on a ‘81 Spider, be adjusted to even the gaps in the corners where the fenders meet the windshield frame? Are shims used to even these gaps or ‘is it what it is’?
Dave
Windshield Adjustment?
- Your car is a: 1981 2000 Spider
Frog2Spider
'81 - 2000 Spider
Frog2Spider
'81 - 2000 Spider
Re: Windshield Adjustment?
To my knowledge the frame only moves back and forth to adjust for door fitment and hood alignment. the fenders can be adjusted. you just have to cut and weld
but don't try and get the gaps to a minimum the front fenders move a lot on rough roads and can chip the paint if they touch.
- Odoyle
Yes, shim where originally used to adjust gaps, they were circular washers with a slot cut out for easy add or removal.
Thanks Odoyle!
Frog2Spider
'81 - 2000 Spider
Frog2Spider
'81 - 2000 Spider
