Turtleback - purpose of two tubes
ward00
Your car is a: 1975 Spider
Post by ward00 »
Now that I have found a turtleback for my IDF's, I'm wondering what the two tubes (no, I'm not talking about the air intakes) that each have an external end and an internal end in the vicinity off the inlet to each IDF were originally used for? I'm sure they weren't used for that purpose, but rather than plugging them off, I feeling tempted to use them to inject some NOS.
75 Spider
75 Sport Coupe restoration
grrrdot
Your car is a: 1967 124
Re: Turtleback - purpose of two tubes
Post by grrrdot »
So not exactly sure but I'll guess its part of the breather system.
On the underside my turtleback is one big nipple for the crankcase vent line that comes off the engine block and two smaller nipples for the vacuum lines that come off the 15/13 IDFs.
Inside the air filter is a housing of sorts that directs all that oil vapor into the carbs.
-G
rebar1111
Patron 2019
Patron 2019
Your car is a: 1979 124Spider
Post by rebar1111 »
That's how I used mine on 40IDF 13/15. It works.
