Low Compression in 3 out of 4 Cylinders
kurtisrich
Your car is a: 1974 Fiat Spider
Post by kurtisrich »
1974 Spider has low compression in 3 out of 4 Cylinders. Please provide any tips and suggestions to troubleshoot. Thanks!
aj81spider
Re: Low Compression in 3 out of 4 Cylinders
Post by aj81spider »
Two possible causes are a blown head gasket and bent valves. I suspect with three cylinders low it's less likely to be bent valves.
For either of these problems pulling the head is the next step.
A.J.
2006 Corvette
kurtisrich
Thanks AJ. That's good to know.
