Crankcase ventilation plugging
- Your car is a: 1979 fiat spider 2000
I want to get rid of my factory aircleaner and plug the two vents on top of motor between the spark plugs but did so and it ran rough what can I do here ??? I have a picture but can’t figure out how to post on here?
- geospider
Re: Crankcase ventilation plugging
1st, use Imgur to post photos: easy.
I just plugged mine up not long ago.
I had only one air port (for lack of a better word right on top of the head. pull the air valve out and match the threads with a short bolt or plumbing plug. cant remember the size.
the PVC comes from below the intake manifold: goes to air cleaner.
Thanks for your response still. A bit lost so u plugged both ports between the spark plugs
- geospider
here is a pic of top of head. You will see 2 plugs along the left side near #2 & 3 spark plug holes.
the one near #2 was already done. the one near #3 I did with a short bolt and copper washer. this is wear the "air valve" was.
hope this helps
Yes I see there both plugged but on the other hand when I did so it ran and stalled which told me it needed to breathe more how so did u go about that? Thank you very much looks like a nice clean motor
- geospider
unsure. All posts I previously saw, did what I did.
I also plugged the pipe going from the exhaust manifold to the head at the front of the head (where the EGR) connects; it may connect with the ports inside; no idea.
when the old stuff was on, I do remember plugging the top of the valve that came out of the head and it did run poorly.
after all the changes I made, never had an issue.
you may try calling AR or Mark at Allison's; both great at giving you quick advise and info
what else are you planning to do?
geo
geo
- geospider
Yeah mine had two air valves on it in both spots did u run a breather hose from the crank underneath your intake to the carb filter I seen some do that
- geospider
yes. the PVC from the block to the carb. there is a spiral metal mesh inside the hose to collect the oil and drip back down.
I have a weber 32/36. just need to run the hose to fit. I'l try to take a pick of thi a bit to fit.
What carb set up are you looking at?
I’m saving for the single plane and yes same as u have either Weber or empi
- Nanonevol
That's a flame trap that is in the crankcase vent hose.
1977 Fiat Spider
1985 Jaguar XJ6
1966 BSA Lightning
1985 Jaguar XJ6
1966 BSA Lightning
- Patron 2019
- Your car is a: 1979 124Spider
Just a clarification: I believe the proper term is PCV for Positive Crankcase Ventilation. PVC is typically for Poly Vinyl Chloride as used in plastic pipe.
- geospider
yep, 2 finger typing gets me every time.
