Fuel filler hose
Fuel filler hose
I bought this 76 spider that was is in pretty bad condition (for about $1500) and here is one problem I need some help with. Right where the fuel filler pipe connects to the fuel tank, has corroded through and is leaking fuel. It seems the previous owner bridged this gap with a plastic corrugated pipe
I've taken the pipe off now and I was lookin' on the fiat parts websites for a replacement but I suspect the rest of the setup isn't stock either because none of the options look like they are what I need, does anyone have any suggestions as to what to do?
Re: Fuel filler hose
You can get that rubber hose at any of the fiat vendors here . Your main down pipe looks a little longer than normal but you may have to move it upward, but you can cut the host to fit also.
- MattVAS
- Your car is a: 1976 Fiat Spider 124
The normal hose works on that car.
Our part number is SKU 30-4360
Hope that helps.
Hope that helps.
Matt Phillips
Vick Auto - Manager
http://www.vickauto.com
Vick Auto - Manager
