The ones I'm having trouble with are the three rectangular gaskets, one with an oval hole and two with round holes. My carb has a spacer between the body and the base, and another spacer between the base and the manifold. Do I sandwich the body/base spacer with the two round holed gaskets, and then put the oval gasket between the bottom spacer and the manifold?
