Why is one carb drawing less air
grasshopper
Post by grasshopper »
Hi all. Im having an issue with my 40 idf's. Im using a synchrometer on them to set them up. The throat closest to firewall draws slightly less air. Can I use my air bypass screws to fine tune it ? Also,just wondering, when screwing the fuel mixture screws in or out, what is the preferred setting? I've read that they should be aprox 1.5 turns out. By this does it mean one full 365 degree turn out of the screwdriver and half more or is half a screwdriver turn considered one turn ? I hope this makes sense,,lol Any help would be appreciated thanks.
rebar1111
Patron 2019
Patron 2019
Your car is a: 1979 124Spider
Re: Why is one carb drawing less air
Post by rebar1111 »
One and one half turns is 360 +180 deg on the screw driver.
