82 Spider Coolant tee
hifijoes
Your car is a: 1982 Fiat Spider
Post by hifijoes »
Just updated my cooling system replace thermostat and fan switch and filling up with coolant. Was almost complete but when I topped up at coolant tee, screw went it sideways and stripped inside tee.
When I replace tee with new, am I going to lose all the coolant I just put in ??
Should be able to capture most of coolant with a oil tray.
Any advise ?
2021 Alfa Romeo Giulia Ti Sport
1982 Fiat Spider 2000
1978 Fiat 124 Spider ( many years ago)
1976 Fiat 128 3P ( many years ago)
1973 MG Midget ( many years ago)
1971 MG BGT ( many years ago )
DRUMMOND
Re: 82 Spider Coolant tee
Post by DRUMMOND »
siphon the coolant out till it is below tee from the rad cap
MattVAS
Your car is a: 1976 Fiat Spider 124
Post by MattVAS »
Best advice I ever got was not to use the tee as the final fill spot.
I've always installed a burp tee in the long heater hose to do the final fill from. This has to be the best trick I ever learned for burping the 124 engine. Also, since I've worked at Vick Auto for coming up on 10 years, you'd all die if you knew how many people strip the front tee trying to burp the air out.
Matt Phillips
Vick Auto - Manager
http://www.vickauto.com
aj81spider
Post by aj81spider »
+1 on the T in the heater hose. Since I've done that burping the system has been easy and error free!
A.J.
2006 Corvette
tima01864
Patron 2021
Patron 2021
Post by tima01864 »
Will the tee bought at the Auto Store fit inside the heater hose?
MattVAS
Post by MattVAS »
It should. Most of them are 5/8" so the generic store should have one that fits.
Matt Phillips
Vick Auto - Manager
