13 to 14
13 to 14
Good afternoon.....Another fun question from the newby. I have the standard 13" rim on my 1981 Spider and I would like to go to a 14". When I go to certain tire suppliers online and put in a 14" rim/wheel nothing comes up or the site tells me there is no match for my vehicle. Any suggestions would be helpful.
Thanks,
WCM
Thanks,
WCM
- geospider
Re: 13 to 14
First you will need to find the 14" rims that will fit. there are some options, but not too many with our bolt pattern.
then just search tires by size vs vehicle. I think the 14's are phasing out.
I just put 15" rims with 55 series tires: fits/feels great
Geo
Geo
Re: 13 to 14
really.....a 15" ? seams a bit tight under there plus how's the turning?
- kmead
Re: 13 to 14
It is about overall diameter of the tire and the rim combination, the diameter of the assembly is driven by the tire size and its aspect ratio.
The OE size was 165/80 13 and later 185/70 13 on a 13” rim.
The last years of Spiders in the US had 185/60 14 tires on 14” rims. The 14” rim from Fiat came in two designs, one called the Turbo used on may 124 Spiders and also a version of the Iron Cross style which came on the rare Anniversary cars. It is also possible to use Maserati Biturbo rims which came mainly in 14” rims sizes.
Going beyond what was offered as standard, one can go up one rim size more by reducing the aspect ratio of the tire further to a 50 series, thus you can go to a 195/50 15 tire on a 15” rim. There were some EU Spiders avialable with a 15” rim (Volumex).
The other requisite is that a Fiat uses a 4 x 98mm bolt circle on the rim, with a postive offset of 25mm, though the offset can be varied a bit depending on the rim width used.
There are several 15” rims you can buy new, some from Mark Allison (he was the first to offer the best looking one in my view) others from Vick Auto, Mid West Bayless as well as Auto Ricambi.
Hope that helps.
Hope that helps.
Karl
1969 Fiat 850 Sports Coupe
1970 Fiat 124 Sports Coupe
1985 Bertone X1/9
1985 Bertone X1/9
Re: 13 to 14
Thanks Karl
Re: 13 to 14
You could just buy the rims and tires I have for sale in the parts section! 15 inch with 50 series tires.
Jeff Klein, Aiken, SC
1989 Spider, sold
2008 Mercedes SL65
2008 S600 Mercedes V12
1989 Spider, sold
2008 Mercedes SL65
Re: 13 to 14
What is the title of the post?
- spidernut
Re: 13 to 14
13" and 14" tires are getting harder and harder to find if you want a quality tire. I gave up and went to 15". I have no problems with the tires at all.
https://allisonsautomotive.com/collecti ... 5_gunmetal
John G.
1977 Spider (Sold 2017)
1979 Spider (Sold 2015)
1980 Spider (Sold in 2013)
1981 Spider (Sold in 1985)
Re: 13 to 14
I think the 15" option is great - if you live in SoCal and drive nice smooth roads. But I don't.
This is definitely a matter of opinion. I don't think the spider has the structural integrity in the cross-member/shock tower setup to handle much more impact harshness than the stock setup provides - at least here in the mid-west where potholes like to kill oversized wheels. There's a balance between unsprung weight, sidewall cushion and structure that should be respected relative to your road /driving conditions.
I'm very pleased with my upgrade to 1980s vintage 14" BiTurbos and new General Altimax tires. Great combination and about 4lbs lighter per wheel/tire at each corner vs stock 13". Huge improvement in handling and ride.
Re: 13 to 14
I went with the Lancia FPS 14" wheels (Midwest Bayless has a reconditioned set and you need to get the studs from them also) with Sumitomo HTR A/S 185/60-14 tires. Those tires are still available.
Link to my post:
http://www.fiatspider.com/f08/viewtopic ... en#p217718
Link to my post:
Warren
Sylacauga Alabama
1991 Alfa Romeo Spider Veloce
1974 Dodge Dart Sport Hang 10 (in restoration)
Multiple other cars, trucks, and boats
Sylacauga Alabama
Re: 13 to 14
"15" wheels and tires" under the parts for sale section.WCM wrote:What is the title of the post?
1989 Spider, sold
2008 Mercedes SL65
1989 Spider, sold
2008 Mercedes SL65
Re: 13 to 14
Warren
Sylacauga Alabama
Sylacauga Alabama
- Your car is a: 1980 Fiat Spider 2000 FI
Re: 13 to 14
Which tire size you put on exactly? Is it 195/60-R14?Slartibartfaster wrote:I think the 15" option is great - if you live in SoCal and drive nice smooth roads. But I don't.
Re: 13 to 14
I used 195/60/14, no rubbing issues and as close to my old tire circumference as as possible so the speedo is 'correct'.
For comparison, the OE tire size was about 165/80/13 = 862 revs per mile
My car had 185/70/13 dunlops when I got it = 869 revs
195/60/14 = 869 revs
Vs OE tires, overall diameter is within about 1/2 inch, 60mph on an accurate speedo will be 59.5 actual. They are a bit over 1' wider in section width.
wheel-size.com has a good calculator
