The PO has all the tubing removed from this. The wires are still connected but I'm quite sure it isn't doing anything. Can i remove it? Im trying to make sense of all the shady tree mechanic stuff going on and clear out stuff that i can if its dead (splices instead of running a new wire, and all sorts of crazy stuff). Also i have a black large canister kind of below it which also has no tube on it. I would normally think it is a vacuum canister, but the engine runs fine, can i remove it also?
Thank you as always.
