headlight adjustment screw hole stripped
- Your car is a: 1976 Fiat Spider
Hi all. I have a Spider that I bought and trying to get sorted out. Passenger side headlight was pointing straight down so I tried to adjust it. In the process I found that the upper adjustment screw hole is stripped. Is there any suggestions as to what I can do to remedy this without getting a new light pot ? Im trying to avoid buying a new one. I live in Canada and between money exchange, shipping charges and duties it gets very expensive. Any advice appreciated thanks.
Re: headlight adjustment screw hole stripped
Grasshopper, had the same situation a few years back. I noticed the hole stripped when installing a headlight relay kit and re-aligning the headlight. Prior Owner had used what looked to be electrical solder to get it to straight forward. I found a similar year car in a junk yard and purchased the headlight and headlight bucket for $15. Its getting harder to find these but may be worth a short trip if you have any salvage yards with listed Fiat Spiders in them.
82 Fiat Spider 2000
03 BMW M3
07 Chevy Suburban
82 Fiat Spider 2000
03 BMW M3
07 Chevy Suburban
Thanks. I managed to straighten out the lamp to visibly look better but I will have to see if the lamps are beeming straight.
