Yahoo! Congrats, geo!
Glad you're running again,...I certainly understand about the LONG, DRAWN OUT, PROCESS of getting things mechanically ready to be back on the road again!
I, and mine, are just a bit ahead of you, and made a first multi-mile run this evening with a PERFECT run.
Best of luck with your's!
Todd.
1988 Mazda RX-7
1979 Fiat Spider 2000
1976 Camaro
1972 VW Superbeetle
1969 Ford F100
1968 Mustang coupe
thanks I am a carb adjustment and alignment away from running on what feels like all new stuff.
will post again.
as well as my Italy experience.
and: posted a vid but dont knnow what to do to make it have sound.
sure sounds good though. love the thoaty Webers that make sense on these great little cars
thanks. was quite a thrill when it stared right up. now timed, even better. running super rich. need to check to carb float adjustments and jets. I put the 32/36 weber that the Po had in a box. not sure how originally set up. did a minor rebuild and thought I got the float right, but feel i need to recheck. and figure out the jetting.
and see if my new Tstat is opening
geo
