Distributor Timing Advance
Frog2Spider
Your car is a: 1981 2000 Spider
Post by Frog2Spider »
I tested my vacuum pot and discovered that it was not allowing or holding any vacuum, so I replaced it. Now, it holds vacuum (when sucked on), and with th D cap off, I can clearly see the distributor plate move. I also checked, and have excelllent vacuum from the manifold hose to the vacuum pot.
With other cars, when I’ve tested a working vacuum advance, the engine rpm increases when the test tube (hose) is sucked on.
However, I’m getting no rpm increase when testing.
It should also be noted that the engine runs fine, performs well and has lots of pick-up.
Any thoughts, deductions or conclusions?
Dave
Frog2Spider
'81 - 2000 Spider
wetminkey
Re: Distributor Timing Advance
Post by wetminkey »
Your answer might be found in a thread that is in the "Performance" section, 'Vacuum advance module for Marelli'. It covers adjusting the vacuum advance module on installation. Mine did not work properly when I first installed it, and I researched the subject a bit,...
Best of luck with your's!
Happy Motoring.
Todd.
1988 Mazda RX-7
1979 Fiat Spider 2000
1976 Camaro
1972 VW Superbeetle
1969 Ford F100
1968 Mustang coupe
Frog2Spider
Thanks!
Dave.
Frog2Spider
'81 - 2000 Spider
