See the picture below. It shows the master cylinder installed without the reservoir hoses and brake line tubes connected. I filled the master cylinder reservoir intakes and as you can see the single outlet for the rear brakes fill's up but the two for the front the reservoir intake fills up but nothing appears in the outlets for the front brakes.
When I had the master cylinder on the bench uninstalled I filled the two reservoirs and all three outlets filled up and started to overflow. After installation I do the same thing and nothing comes out the front brake outlets.
Is this because the booster plunger is sticking out too far?
This is my second time doing this with the same parts. The first time I bench bled the master cylinder in the vice. I "bench" bled the mater cylinder in the car still nothing.
Again, I can't get the plunger in any further. Could I possibly put a gasket between the master cylinder and the booster? That would bring the master cylinder farther away from the plunger? This is really driving me crazy. I've been dealing with this for two weeks now. Any ideas.
John
