Not having much luck finding info on this.
On my restoration project ('78) the last items I have to remove are the vent window frames and trim atop the doors. Does entire window regulator need to come out?
Any direction is very much appreciated.
How to remove vent window and door top trim?
- Your car is a: 1978 Spider 124 5 spd
Re: How to remove vent window and door top trim?
Bump. Really? No one here has taken top trim off a door before?
- focodave
I've removed the top door trim on both of my doors, but I have never removed the vent window frames.
To remove the top door trim, you simply pry it off, starting at the back of the door. You will need to protect your paint when prying with a screwdriver. I laid some heavy cloth on the door and gently caught the edge of the trim with a large screwdriver and proceeded to pry the trim up and off.
The only problem is that the trim tends to occasionally want to "walk up" (on its own after having re-installed it), after several drives and opening and closing of the doors.
Not a huge deal --- just a nuisance item when I have to push the trim back down once in a while, to get it back in its proper place. It only walks up about 3/16" on the front side of the door and is easily pushed back down in place.
If someone knows a cure for that, I'd love to hear how you fixed it.
1970 MGB GT (my other hobby)
Mine will come off if i grip it when I close the door from inside with the window down...try thatJustice777 wrote:Not having much luck finding info on this.
- riverdadd
- Your car is a: 1975 Fiat Spider 1977 Alfa Spider
look at DRUMMOND post 1980 resto phase 2 (within this restoration projects sub category)......page 3 toward bottom... thats where he goes indepth on the window frame.....The whole entire post is worth a read... really awesome work, with great pictures. but be prepared. his stuff will make you want to mod yours!! i know i do after reading!!
riverdadd
riverdadd
Thanks so much!
Thank you - I got it all apart. Was worried I would have to remove window mechanics and very happy I did not have to.
