Cannot find reverse
Joeype70
Cannot find reverse
Post by Joeype70 »
On my 79 Pininfarina i cannot seem to get my trans to shift/find reverse? 1st through 5th engage perfectly, but for whatever reason I cannot shift or find reverse. Any reason or remedy to this? Thank you!
riverdadd
Your car is a: 1975 Fiat Spider 1977 Alfa Spider
Re: Cannot find reverse
Post by riverdadd »
you need to either pull up or push down in order to get past lock out mechanism. on my 76 i have to push down while in neutral and then i can select reverse
Frog2Spider
Your car is a: 1981 2000 Spider
Post by Frog2Spider »
From the neutral position, push down, swing right and pull back, all in one smooth motion. Don't force or try to make the shifter do anything it doesn't want to do naturally. It can be a little tricky, until you get used to it.
Dave.
Frog2Spider
'81 - 2000 Spider
Joeype70
Post by Joeype70 »
Awesome, thank you. Never new that.
Joeype70
Post by Joeype70 »
Well it worked like a charm, thanks so much!!!
