After re install car won't go in reverse
Posted: Sun Sep 17, 2017 9:15 pm
I pulled engine and transmission on my 82 in order to paint and do all new gaskets. Today was the first day I actually tried to move the car since it has been reinstalled. Engine starts and is running ok-needs a little adjusting. The transmission will not go into reverse-Possibly not 5th either but its a little hard to tell that for sure with no shit knob installed.. I am not sure where to start with the diagnosis of the problem. It seems to shift 1-4 ok but there again I am not positive because I haven't driven it. I did not rebuild the transmission simply washed it and reinstalled it and the clutch using a clutch alignment tools. I did put a new doughnut and center mount and u joints on the drive shaft as well as a new pinion seal in the rear end.
Does anyone have a suggestion on where to start. Id hate to have to pull out the transmisssion.
Thanks for the help.
David
David
