Does anyone know if one can buy rubber front suspension bushes instead of nylon (to soften the ride) ??
Baz
Susp bushes
Re: Susp bushes
ASFAIK - The standard bushings are rubber and the brightly colored ones are polyurethane. Vicks, Alisons and Ricambi most of the time stock both.Baz wrote:Does anyone know if one can buy rubber front suspension bushes instead of nylon (to soften the ride) ??
Baz
Standard tire pressure should be at about 26 psi so I would start there and then verify if you have adjustable shocks set too stiff or possibly too stiff a set of shock absorbers for your preference.
