Im about to install a FPR on my 78. I keep reading more and more about the benefits of check valves.
Is it true it helps with vapor lock? Im in Texas and it gets HOT! (or is this the opposite effect, keeping fuel under the hood and heating it up?)
Also, where do I install it? I see on the micro slides = a few inches after the carb on the return hose.
Or if on supply, do I install before the FRP or after? I had it simply on the supply line before I ripped all the rubber out, and it worked pretty great, instant start ups.
Thanks!
