Hi,
Is the "dished" driver's side cam cover absolutely required for the fuel injection intake/plenum/etc. to fit, or is there still enough clearance if you retain the original cover?
I thought I read over the winter it would indeed fit but I can't find that info again so now I'm not sure.
79 fuel injection swap
- Your car is a: 1979 Spider
- AndyVAS
- Your car is a: 1980 Fiat 124 Spider
Re: 79 fuel injection swap
Sometimes it will just barely fit. If it does, and you use it, you'll need to remove the upper intake to remove the cover to adjust valves.
Andy Phillips
Vick Auto - Technician, Performance Engine Builder & PFI Developer (with ITBs)
http://www.vickauto.com
