Going 5mph sitting still
zachmac
Post by zachmac »
I have started driving the car after the long rebuild and I expected some speedo error (205 50 15 tires) but not 10 mph difference at 60 mph (slower indicated than actual). I get the whole rolling diameter versus original and speedo drive gear thing. BUT, the calculators out there say I should be seeing a few percent error, not 17%.
Here's the thing though, parked in the garage the speedo reads half way between zero and 10 mph (~5 mph). I gotta believe this is contributing to the error I am seeing. Has anyone else seen this? Is there any sort of zero set that can be adjusted on the speedo?
On the other hand since I like to drive about 10 over the speed limit (seems to be the range they won't ticket you for) maybe I leave it alone and drive the speed limit knowing I am actually about 9 to 10 mph over. :D
Jeff Klein, Aiken, SC
1989 Spider, sold
2008 Mercedes SL65
2008 S600 Mercedes V12
azruss
Re: Going 5mph sitting still
Post by azruss »
When I rebuilt my car, I put in one of 4 good speedos i had. It was fine for a while but started reading higher and higher. It wasn't long before it was reading 70 at 35. I changed out the speedo to one that was more accurate. Haven't had any issues with the one i have in the car.
joelittel
Post by joelittel »
Mine reads 5mph while standing still as well.
If there is a fix that doesn't require getting a new to me speedometer I'd be interested in hearing about it too.
Jon124
Post by Jon124 »
Is there a pin in the speedometer at 5mph? On the kph speedometers there is a pin at 10kph so it can't read any lower.
1974 Honda CB350F
1981 Fiat Spider 2000
micbrody
Your car is a: 1981 fiat 2000
Post by micbrody »
my speedometer also shows roughly 5 mph when parked. If I tap the speedo hard with fingernail, it goes down to zero.
I did previously disassemble it ; i think it's just related to some friction on post that is connected to spring. I wish I added some lubricant at this point, which I did not. Just not worth disassembly for this
joelittel
Post by joelittel »
Not sure about the pin, but I don't recall there being one. If there were I doubt I would think it odd that the needle rested on it at a stop.
This will go on my " May never get to it" list
zachmac
Post by zachmac »
joelittel wrote:Not sure about the pin, but I don't recall there being one. If there were I doubt I would think it odd that the needle rested on it at a stop.
While not on my "never get to list" it is certainly on my "when I am really bored" list. :D I'll try tapping hard as suggested above.
1989 Spider, sold
2008 Mercedes SL65
klweimer
Post by klweimer »
My speedo has never been very accurate, and it seems to vary with, ...well who knows what? If I'm worried about speed, I have a simple GPS app on my phone that I can turn on to compare to.
Kirk
blazingspider
Your car is a: 1977 fiat spider
Post by blazingspider »
The speedo on my 77 which is original to the car has a little pin that stops the speedo needle at about 5 mph. The pin is above and inboard a bit from the 0 on the speedo. Tough to see but it's there.
